actually i think it might be power steering leak. Anybody have any common areas to check?
sorry that would help huh......2015.What year?
I thought it was trans fluid. It's done it before a few times where it pukes out fluid a bit, then fine for month. Last 2 days it's been dropping fluid so trying to figure out what to check on it .
Clean it up.....take a lookIt’s def a coolant leak. No idea where though it’s above and leaking down
Look at the heater tee above the left side of the motor, and don't rule out the heater core. Check to see if the carpet's wet. Does the heater blow moisture that smells like coolant? Look at the aluminum lines on the side of the frame that connect to the rear heater if you have one.
