On checking the live or KOEO data, is reads MIL_DIST 0km/mi. Does that mean I have driven enough miles since erasing codes? It used to show P1000 - must drive more miles.
If this is good to go (GTG) and a pending code won't trigger a FAIL at inspection, it'll be a beeline after I get some feedback.
I'm not an expert by any means, but I do practically all of my own auto repairs as I do enjoy the satisfaction of repairing them myself!
From what I have read AND from what I have been told by an experienced professional, once the P0442 is set as a pending code, it will remain in place until another EVAP drive cycle is triggered. At that time, if the drive cycle is completed, it will either pass EVAP and erase the pending code automatically OR it will fail the drive cycle and then set the appropriate code (P0442 in your case) along with illuminating the "Check Engine" Light (MIL).
I have also heard that an auto can not pass inspection with a pending MIL. I don't know if that is true or not?
By the way, and this is very important, whatever smoke machine you may eventually purchase, borrow or rent, make certain it will not apply any more than 3 to 5 PSI MAX to the EVAP system. The tag on my Expy's purge valve states to apply no more than 1 PSI. It's my understanding there are some components within the system that can be easily damaged if too much pressure is applied to them.
The smoke machine I purchased will only apply 0.5 PSI to the system. I can also assure you 0.5 PSI is more than adequate.
