1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Trying to get rid of P0442 - small Evap Leak
Discussion in '2nd Gen - 2003 - 2006' started by RichardH, May 15, 2020.
  1. tvlunn
    tvlunn Active Member
    32
    Sep 1, 2008
    Just in case you're curious, the Ford EVAP drive cycle is as follows:
    > Auto will have to soak or engine off for 6 hour minimum
    > Fuel Level must be between 15 and 85%
    > Cruise at 72 to 104 Km/h (45 to 65 MPH) for 10 minutes - avoid sharp turns and hills
    These are the basics to initiate EVAP test
  2. RichardH
    RichardH Full Access Members
    173
    34
    Nov 20, 2015
    Galveston, TX
    Thank you, I intend to do a short toll run tomorrow morning, and make a beeline to my shop. Will see what the free test says. I hope it's a go.
    Again, thanks for the info - I'm at 50% tank right now. I'll even manually run it through the gears so as to not agitate the tank, which I believe part of the above measures is for (turns/hills).
    Dick
Share This Page
