Turn signal LED replacement brand?
adamsdaddy
Orange County
My right rear turn signal died so I replaced them both with cheap incandescent bulbs. The housing were brown and blackened from too much heat. I’d like to replace them with LEDs but I don’t want to mess with splicing in a resistor if they throw an error or do the rapid blink.
I have a 2016 XLT and if you have replaced your turn signal bulbs with LEDs without experiencing the rapid blinking then please reply with the brand and model.
thank you
Robert McMillan
US
thank you
JDM Astar
Langer
Chicago
You can use forscan to disable the hyper flash when using an LED bulb.
Langer
Chicago
Thanks but I don’t own a Forscan adapter and they run $30 on Amazon which would make these $50 ($20 LEDs plus $30)light bulbs.
Return it when you’re done with it? Lots of diagnostic stuff you can do with it in addition to code alterations, too.
Goofy173
Ky
Adding resistors are as easy as replacing bulbs. All my 2011 Expy signals are LED and with resistors. Did them all in 1 hour.
A
adamsdaddy
Orange County
I added the LEDs to the rear turn signals. No hyperflash during the day. I just learned that they behave differently at night - hyperflash. Bummer.
Back to Amazon they will go and back in go the incandescent bulbs. Not worth anymore of my time.
07navi
Mt.Shasta California
I never could figure out why everybody keeps messing with them anyway when the stock ones are fully adequate.
Robert McMillan
US
Bc LED are superior to ****** halogen. Have you tried LED lows or highs on your truck? Doubt it, LED is a far superior difference than halogen
07navi
I could never figure out why you ***** so much about what other people do to their cars.
I can't figure why you would harass someone from behind a keyboard that you don't even know. I try to help people but most are too naïve to grasp good advice.
A
adamsdaddy
Orange County
Take a look at the picture in my initial post. The incandescent bulbs were literally burning up the sockets. I wanted LEDs because they run cooler while producing the same or slightly higher level of brightness. Resistors generate heat which is what I was trying eliminate in the first place.
Robert McMillan
US
Yeah I've seen resistors burn through wiring harnesses and plastic parts of the head/tail light housings. Not good
