Urgent help please with 98 exp.
isanchezgdl
mexico
Hello all, how are you?.
I have an exp 98 eddie bauer and yesterday in the morning I change the fuel filter, after that all seems to be normal, I take the expy and travel out the city, after a stop in the gas station the lights of low fuel, oil/temp and Theft blink once, I don't know why happend this, nothing happened during the trip, but in the night when I return home this happen again, first star blinking only the low fuel and oil/temp warning lights, blinks and pass a few mins and blink again, then this 2 lights + anti-theft and the truck tries to turn off once, after this again every thing was normal. Today same history but with no warning light, just turn off the engine.
What can cause this? is for the fuel filter change? I'm worried about this, I don't know how fix it, or what happend?.
The check engine light just have the P0155 code, do I need to scan the truck again?
Thanks a lot for your help
I
isanchezgdl
mexico
some guy in the office told me that could be a bad gasoline (gasoline+water), can this produce this problem to?
omegalita
Switzerland, SG
The error code P0155 indicates a faulty oxygen sensor but it can be only a mass problem...
I would lie under the car and see whether a connection is loose, or if a cable is defective.
And check the fuel pump and the connectivity also.
