Urgent Help with expy 98
isanchezgdl
mexico
Hello every one, I have a problem with my expedition eb 98, 3 days ago start to do something strange, the indication lamps of oil and gas turn on for a second and then all turn off, when I try to start the engine again I don't have any light on the dashboard, like the expy don't have power, but the interior lights was turned on. What I did was unplug the battery wait a minute and then plug in again, then start again, but a few minutes later happend the same, the gas and oil lights come on and a few seconds turn off again. The difference in this month with the past was I full the tank. I will try to get a scanner but if you can give me some help I will appreciate a lot, this is my only vehicle and I live 15miles from city.
Thanks in advance for your help, I really don't know what could be, a relay, pump, sensor, I don't know.
Best regards
ArtGamer60
Roy , UT
Your best bet is to get a scanner , iit could be alot of things from the gem module to something stupid , like a connection , .. ie loose or frayed wiring .
FordandPolaris
Saint Cloud, MN
I have heard of a soldering joint on the back of the dash wearing over time and consequently causing the dash to act strangely. Unfortunately you have to remove the dash, but its a fairly straight forward fix. Do some googling on ford expedition dash soldering.
I
isanchezgdl
mexico
Thanks to all for your answers, the scanners results was no codes, it's fine, and the guy told me that maybe could be wather on the tank, I buy a fuel system cleaner (rislone) in autozone and I put in the tank, until now I don't have any failure, but I don't know if this problem could be caused by a bad gasoline, or whater on it, the gas filter is new (10 days ago) I have no leaks, and I will check the wiring and belt in a few moments.
Do you know how to check if a relay is ok? for also check the relays (the fuses all are ok).
Thanks again to all for your answers, if I don't have any failure this weekend, I will post a new replay with problem fixed.
Have a nice weekend. If you have any other idea is welcome.
ArtGamer60
Roy , UT
I had the same problem with the gas , when it hit 0 miles to empty ? got that fixed , when I first got my truck running again , as it sat for months , glad to hear that you got it fixed . I would look for something stupid first . Usually the kind of problem with 4 guys standing around , and some guy comes over and looks and says ? you may want to hook up the coil wire ..
I
isanchezgdl
mexico
was to fast for say "problem fixed" after driving 15mins aprox. the truck stop again, I really don't know what could be, I don't have error codes in the scanner, the fuel filter is new, no leaks, all fuses ok, how can I know if the fuel pump is the problem? and in autozone there is 2 options with the pump, complete or just a spare part, like a cilinder.
Any ideas? I really need your help, when shutdown if I turn of the switch and open again I don't have any indication lamp turned on before start, as allways happen when you insert the key and turn to start, all lighs come on, and that don't happend I need wait a few for start again and see all the lights on in the dashboard. Any ideas? note: all the interior light, windows, chime, etc. works perfect, just the indicator in the dashboard don't (battery gauge, indication lamps, brake, gas)
Thanks for your help
1997SCEBFEX
Northwest Panhandle
Sir,
how old is your alternator? these are similar, not all, symptoms i had when my alternator went bad. it would just shut off, sometimes restart, and barely stay running with many lights/indicators flashing on the dashboard.
for fuel pump, you should hear it energizing when you turn the key to the first position prior to engaging the starter. Is there any chance that someone hit your vehicle and it triggered the fuel cutoff inertia switch? I've never heard of it doing this, but have to ask. I'd check that connector too...should be on the passenger side kick panel to the right and below the glove box. pull that panel off and push the button.
PanHandler.
ArtGamer60
Roy , UT
Could be something as simple as a ground or intermittent lack of . good advice from the previous poster ...
I
isanchezgdl
mexico
The alternator was fixed the last year, there is a way for check if the alternator is ok? The only lights flashing and just one or two times are oil and gas, at same time, after that the truck turn off .
1997SCEBFEX
Northwest Panhandle
to clarify, you say oil & "gas" lights flashing?
is your oil pressure gauge reading correctly? I deduce your oil level is o.k. too?
ArtGamer60
Roy , UT
Disconnect the positive lead from the battery , while it is running , be careful not to short it , if it dies ? most likely the alternator , you didn't mention a dead battery ? or problems starting it , as far as electrical ? look for a broken or loose wire ...
diesel3
jeffersonville ky
as already stated by another member on this thread, the 1st gen expeditions had dash problems with weak sodder joints, mine did its a 99 xlt. but if its killing your truck, i dont think your dash is the problem. you asked how to check your fuel pump? you can have the pressure tested at the fuel rails and compair with pressure specs for your model year. also some vehicles have a safety shut off on the oil sending unit that will shut your engine down if oil pressure gets too low to save your motor, dont know if the expeditions have them but if they do, when your oil light flashes on it would most likely shut your motor down
ArtGamer60
Roy , UT
" when shutdown if I turn of the switch and open again I don't have any indication lamp turned on before start, as allways happen when you insert the key and turn to start, all lighs come on, and that don't happend I need wait a few for start again and see all the lights on in the dashboard. "
It almost looks like a short , or a relay ? The dash should light up resetting all your gauges and idiot lights upon restart , you have to wait ? for it to cool off ? hmm
I
isanchezgdl
mexico
For oil gas lights I mean the yellow low fuel warning light and the oil/temp warning light, the pressure gauge is ok, and also the fuel gauge.
This lights flash for one or two times before shutdown.
The battery charge is ok, 14 running and 12.4 turned off, but but 3 times where it shutdown today all the lights that normally turns on when open your switch before start your engine (battery, Abs, a4wd, 4x4, low fuel, etc) not turned on when I open again the switch to start possition, just a few seconds latter and then start normally.
I have a question about the alternator test, if I disconect the positivo pole of the battery and the alternator is fine, the truck will stay running? Or after some time will shutdown? And if the alternator is bad, how fast will turn off the engine after disconect the positive pole? I will do this as soon I know the answer.
ArtGamer60
Roy , UT
It should stay running as far as the alternator always , it will run off of the battery if the alternator is bad and slowly discharge your battery hence disconnect ( easy test ) I wonder if it is the ignition switch itself ? so you turn it off ? and get nothing ? it doesn't stop running and die ?
Temple, Georgia
Your alternator is fine by the readings that you posted. You most likely have a loose or broken connection that is cutting power to the dash/pcm. Since you have to cycle the ignition switch repeatedly that would be the second thing that I would look at. The first being good battery and ground connections.
From the diagram on FordParts.com it looks like the ignition switch is located towards the back of the steering column on the underside. I would also check the connector that plugs into the switch for obvious damage from heat - browning of the connector.
I
isanchezgdl
mexico
Alternator test pased. Tomorrow I will check connectors in gas pump and the ignition switch. I will keep you informed. Thanks to all. For today I think is all.
BANGEREXPO76
PLUGZONE 76
Sir,
PanHandler.
I was gonna mention the alternator but I see you already did the check there.
