isanchezgdl
The alternator was fixed the last year, there is a way for check if the alternator is ok? The only lights flashing and just one or two times are oil and gas, at same time, after that the truck turn off .
Sir,
how old is your alternator? these are similar, not all, symptoms i had when my alternator went bad. it would just shut off, sometimes restart, and barely stay running with many lights/indicators flashing on the dashboard.
for fuel pump, you should hear it energizing when you turn the key to the first position prior to engaging the starter. Is there any chance that someone hit your vehicle and it triggered the fuel cutoff inertia switch? I've never heard of it doing this, but have to ask. I'd check that connector too...should be on the passenger side kick panel to the right and below the glove box. pull that panel off and push the button.
PanHandler.
