So that was an easy fix. Piece of rubber hose and now my vent blow again instead of just my defroster. Now I just have to figure out why it’s misfiring still
For the P0446 code you need to check the condition of the wiring harness/plug and the actually functionality of the evap vacuum control valve back there above the spare tire. Lower the spare to get to it. Sometimes that control valve just wears out. Other times it's the ground wire in the harness lead itself. Any little crack in the insulation of the wiring will allow corrosion to set in and disturb the current flow to the control valve.
Here's a good video describing the trouble shooting of the valve.
