Just bought a 2008 with 140k on the clock. At highway speeds the steering it tends to be pretty "touchy". It will wander to one side and when you correct it over steers to the other side. I checked the front end and everything seems to be OK. In fact, it all looks like new. None of the rubber appears to be deteriorated or torn all the end links look good, no leaks from the rack, steering seems tight, ball joints good. I am left with replacing the struts and getting the alignment checked. No leaks from the struts but I will bet they are original. Same in the rear. I have a 92 f250 and 3 Chevy 3500s so I am used to driving trucks and they all handle just fine. Anything I might be overlooking? Would struts give these symptoms? Any input would be appreciated. THANKS!!!!
