Valve Seal Leak.... PLS HELP!!!
14secExpedition
wichita, KS
Ok so yeah... I am new to this forum.. Found it like it and need some help please!!!
I have a 2000 Ford Expedition Eddie Bauer 5.4L
And yes my valve seals are leaking. When I start the car white smoke fills the sky and its very very embarrassing.
My question is can I get new cylinder heads for this SUV. I don't neccessarly want the factory cylinder head. I want an aftermarket one that would improve my proformance. Does anyone have any suggestions in this matter???
And will replacing the cylinder heads evey fix my problem?
Will it come with valves?
Again pls help and thank you for all the advise.
Here are the specs on my SUV if it helps.
K&N intake
Magna Charger Supercharger
Gibson Headers and Exhaust
MSD Digital 6 ignition system
shov76
Connecticut
White smoke dosen't seem like oil which is what would be leaking past the valve seals. I'm not a mechanic but I thought white was water and blue was oil. I could be wrong. Either way, good luck
Shov
GABE
corona ca
I had a car that also put out smoke when first started the engine, I was using regular oil, but when I put sintetic blend (cheaper then full sintetic) the smoke stoped completly forever.
