I understand that this is a common problem but I am baffled.
The front vents blow warm air while the rear blows cold. The blend door which I accessed by cutting a hole through the glove box is working fine. It's almost like there is no air being forced through the evaporator coil. The lines under the hood are cold leading to the coil. I am no A/C expert.
Any suggestions?
Any suggestions?
