Washer Fluid Pump Help Needed
oskarol
Toronto
Hello All,
I'm in major need of some help here. Have tried everything without success on my 2007 Expedition SSV.
Symptom - Front and rear wipers both active but washer fluid pump does not run.
I have checked power at the pump and it is not getting power at all. I already bought a new pump thinking that would for sure be the issue and obviously it does nothing. The fuses are powered and since the wipers all run, I cannot imagine that is the issue.
This may be coincidental, but very recently I added a 3rd row seat to the SSV. To power the 3rd row, I tied into the cargo power outlet. I cannot remember if the washer pump worked after I did this but I cannot see how it could be related.
I am in desperate need of some help here as the snow/slush around here is making the vehicle undriveable in this condition.
Thanks in advance.
O
oskarol
Toronto
Where are the relays... not seeing anything listed in the fuse box under the hood except a single 30amp wiper/washer fuse, which is good.
