We got our brake kits in finally!! $299.99.
ONEBADMK8
NJ
Been waiting 3 weeks but we finally got our drilled & slotted rotor kits in. $299.99 plus a flat rate of $19.99 anywhere in the USA!!
This is for Ford Expeditions Produced Between 3/18/02 - 2006 2wd or 4wd
Heres the info on the pads.
Dynamometer tested using SAEJ2430 requirements for safe and fade resistant braking
Flame scorching of the pad surface to improve green (Pre-Burnish) pad bite
Ceramic pads are 100% non-ferrous so there is no steel & iron in the pad that cause annoying brake squeal
Low dust formulation
All pads come with a constrained layer steel shim with two active rubber layers to silence brake noise
Positive mold hot pressing to eliminate soft spots inside the pad
Powerstop is a leading supplier of performance brake parts since 1997
Heres the zinc coated Kinetic rotor info,
Castings are made using SAEJ431 metallurgy from ISO9000 registered foundries
Large drill holes reduce stress risers
Holes are engineered for optimum cooling to prevent rotor warping
Zinc-dichromate plating resists rust for years and provides much better protection than painted rotors
Precision machined using state of the art CNC machine for perfect fit and balance
Custom chamfered holes to prevent rotor cracking
Info on the stopping power.
Cross-drilled rotors can improve stopping power up to 35% over stock rotors as reported in SAE Technical Paper 2006-01-0691 "The effect of Rotor Cross drilling on Brake Performance" by two GM engineers. That's why Corvette, Porsche, Mercedes, and BMW vehicles come factory direct with drilled brake rotors, i.e. not dimpled or slotted. The fact is that the drill holes greatly improve convection heat transfer and the result is more pad bite. The report also states that "it is possible to have too many holes; in which case too much cooling air would be lost before reaching the hottest part of the rotor". Kinetic rotors are designed for optimum rotor cooling and durability with one cooling hole per vane. This also provides superior strength to avoid cracking.
Stops rotoe warping
High rotor temperature can cause heat spots to form on the rotor, and this causes pulsating brakes. Cross-drilled rotors keep the brakes up a 150 degrees cooler to prevent rotor warping.
Evolution Power Stop Pads!!
Most OE vehicles come with ceramic pads. Power Stop’s Evolution pads are the perfect replacement for serious street performance. All pads are made using positive mold technology for quiet, consistent braking. Pads are chamfered and slotted like the OE, and come with dual layer rubber shims.
Sorry about taking the crappy pic on our office floor. Ill have better pics soon.
ONEBADMK8
ONEBADMK8
NJ
Forgot to mention, these are Brembo rotors too.
ONEBADMK8
ONEBADMK8
NJ
This price expires at the end of August 2010.
Rider
Grand Rapids, MI
Brembo rotors? I have Brembo rotors on my Maxima and they rust out very quickly. To the point where the rim will rust to the rotor between tire rotations.
Newport News, VA
how long did it take for that to happen...so far no probs for me...and my powerstop setup
firemann32
Missouri
Man I just saw this kit?
Can someone tell me if these kits are still available, yes I realize the price won't be the same.
phocker
Layton UT
Just to info you guys in this thread I just had this delivered after I got it on ebay for 188.95 with free shipping.
phocker
Layton UT
The kit I bought was from brakemotive it was the slotted crossdrilled four pack with ceramic pads it was $188 with free shipping and I have a 05 4wd, and I love these brakes they are a vast improvement over stock.
phocker
Layton UT
This is the link to the ones I bought but it seems the price went up a little!
http://shop.ebay.com/i.html?Make=Ford&Model=Expedition&Model%2520Year=2005&_nkw=2005%20ford%20expedition%20brakes&_dmpt=Motors_Car_Truck_Parts_Accessories&_fln=1&_ssov=1&_trksid=p3286.c0.m282&LH_SpecificSeller=1..brakemotive76
