What android app to use for OBD/trouble codes?
richs fishes
Long Island, NY
I've been using the free version of Torque on my cars to check the trouble codes with a CEL and/or to monitor various parameters. I'll be towing a camper for the first time next week and was hoping to maybe be able to monitor transmission temps on my 08 EL, but apparently cant do this on the free version of Torque.
So what apps might anyone else be using and/or recommend?
mquick5
Buckeye Country
I think you meant forscan lite. I haven't used it yet, been playing with torque pro. And torque pro has three options for transmission temps. I can't say for sure which if any work. But if I was OP I'd try the paid version of torque pro, it's just a one time fee. I like it so far, and have used it on 2 Fords and 3 chevys. Some of the GM options work on the Fords. I didn't like seeing the instaintanus fuel milage, while driving my Mustang! I got it mainly for tire pressures, since Ford decided not to let us monitor tire pressures, even though the vehicle does???
Sent from my couch using Tapatalk
HawkX66
Semper Fi!
VA/MA
Yepper. I have Torque Pro also.
I didnt know there was an android app? I've been meaning to learn more about Forscan just to see what I could change on my own, but really dont know how to use it at all!
Forscan has been very handy for a few things. Like mquick5 posted, the android app is Forscan Lite.
R
richs fishes
Long Island, NY
Yeah Torque pro was what I initially thought I'd be going for, but now I'll have to do some research about Forscan Lite as well.
So I can monitor individual tire pressures on my 08 (with an app) or is that limited to newer models?
Edit: I got Torque Pro but dont see any options for seeing tire pressures. Oh well. It does give me transmission temp at least.
mquick5
Buckeye Country
Well atleast you got the trans temp. Does your 08 have Tire pressure monitors in the tires, and the low air pressure warning on the dash? Here's a screen shot from TP where I enabled each tire.
I'm new to this stuff, and recently found out when making the custom dash, if your connected to vehicle, you will see what options work and what dont, before selecting them. If setting it up unhook your blind. 5b333b4185c62555c836580b92706927.jpg
mquick5
Buckeye Country
Also forscan lite is just for monitoring and check engine codes. For programming you will need Forscan and a laptop.
R
richs fishes
Long Island, NY
Yes I definitely have TPMS and will/can get a low pressure warning on the dash with no specific tire noted. I'll have to play with the Torque Pro app a bit more...I quickly set it up while connected to the car but dont recall seeing anything that was "ford specific" the way your dash shows.
R
richs fishes
Long Island, NY
Yes that I know.....I have an older blue tooth OBD "adapter" that I've been using for years and recently bought the one I'd need (with the switch and usb cable) for using Forscan and a laptop. One of these days I'll get around to learning how to actually use Forscan for what it can really do!
Adieu
SoCal
Earlier years TPMS isn't in the valve stem and just crunches numbers from the traction control computer or something to detect when one wheel is behaving differently from the rest
It doesn't have pressure numbers, it just senses when one corner is out of whack. Other things like vibration and balance issues can set it off too
Muddy Bean
Torque app kept disabling my power running boards. Weird but true. I quit using it and use a Scangauge II now
mquick5
Buckeye Country
You have to go in to the settings and get the list of predefined pids for Ford.
curtis-bob
Kansas
Forscan. FORSCAN. Its computer counterpart is a reverse engineered software from the ford software. Forscan light is almost just as capable.. When it comes to ford scanning tools I only use Forscan. I wish there was something as nice for GM.
HawkX66
Semper Fi!
VA/MA
The only thing I noticed that it's really missing is the ability to code a new Intelligent Access key. I hope they figure that out at some point. I only have one fob and $120 to do it at the dealer just isn't right...
R
richs fishes
Long Island, NY
So after playing around with both Torque Pro and Forscan Lite, Forscan is definitely the way to go! Torque pro could not actually get me any transmission temps. There were at least 2 (or maybe more) ways to try, and either they gave no data at all, or the trans temp was always exactly the same temperature as the coolant. Using Forscan got me trans temps with no problems and it was never the same as the coolant! Was also nice to be able to see what gear I was in while towing as well as all the other displays. Could not get either to display anything about the tire pressures, but using Forscan I could see that the tpms dash light was not on.
