What is the part called...?
MaverikDS
Chico
So I have been trying to locate a part but do not know what it is called or what the stock number from Ford is for it. I have a 2001 XLT and the bezel/trim piece that goes around the rear passenger side window has a broken clip. The window still operates perfectly, but if you want to you can lift the piece up. I can see that one of the clips is broken off and I would like to try and replace just that piece of plastic without having to buy a new switch or anything else. Does anyone know what that piece is called and how much it should cost? I would like to try to find it without going to the stealership and paying an arm and a leg for an essentially cosmetic issue that is not a real problem.
tmajikman
Cartersville GA
The junk yard is an option, but if you can post a picture, it would really help, places like junkyarddog.com are great if you don't have a local salvage yard around you.
