What oil filter do I need?
Eric
California
I am going to change the engine oil for the first time since I bought my 2005 Expy. The prior owner used synthetic oil so I am going to use it as well, Mobil 1 is what I got. Anyway I am trying to confirm the proper oil filter for the 5.4 engine, the one that is on it is all white and has no markings. I checked a Fram book at Walmart and it says PH8 or PH2 depending on the thread size, can anyone confirm what the proper part # is for the Fram extraguard filter I need?
nvycrmn
Springville, IA
usually it will tell you which one for which engine. never seen 2 with different thread counts/size....
trdragons44
nj
stay AWAY from fram they break apart internally and clog up some oil passages. I use motorcraft personally no problems. FL-820S is the motorcraft number. I believe they been using them since 96/97 to present 4.6 and 5.4 V8 on all fordmoco vehicles.
ELVATO
Orlando, FL
Yep, FL-820S. Some of the Walmarts have a little computer (instead of the large book) that gives you filter types, oil capacity, and weight.
RUFFSTUFF
GEORGIA
So you had a Fram filter break internally on you?
trdragons44
nj
Yea some scary shit when u pull ur filter off and all the filter elemnt falls out when u go to drain it.
E
Eric
California
Our local Walmart has Motorcraft but not the FL-820S size. I have used Fram for 15 years and never had one fail, but not saying it can't happen. Anyone know who makes the filters for Ford?
I noted that Fram has a new Xtended Guard filter advertised as being designed for use with full synthetic oil, suposedly allows longer time between changes. Anyone have experience with this filter? They are $8 which is certainly more expensive but could be worth every penny if it cleans the oil better.
smo0othride
San Diego, CA
I have also heard lots of bad stories about Fram filters, Motorcraft makes the filters for Ford.
RUFFSTUFF
GEORGIA
I've used Fram for hundreds of thousands of miles in cars, trucks and motorcycles and have never had a problem. Of the 5 current vehicles I have now, only my Mazda3 doesn't have a Fram. To each his own.
Newport News, VA
i knew a guy that was an air force mechanic...had a sweet mustang redone under the hood and his f150...he advised me that no matter what mod i do to my truck, always use MOTORCRAFT...not just your regular filter but specifically designed for ford vehicles...not like universals...(FRAM, K&N)...so thats what i do.
ELVATO
Orlando, FL
Purolator makes the Motorcraft filters. At least for the 04-08 F150s, Frams are the ones responsible for startup noise. Something about the anti drain back valve.
seeker
Acworth Ga
Automotive Parts
I worked in automotive parts for a dealership for fourteen years. I cant tell you the hundreds of times I sold a factory oil filter to someone that was complaining about engine noise (lack of proper lubrication due to restricted oil flow). It always seem to fix the problem.
I actually was in a manufactures class and was shown 50 different filters that had been cut in half. It was very interesting to see the variations. After that I have always used the manufactures filters. What you don't see on the outside will make a difference. Even if you spend as much as 10 dollars difference for each filter and change oil 3 times a year, you'll spend 30 bucks a year. Try to pick up extended warranty that cheap. There's my 2 cents worth.
RUFFSTUFF
GEORGIA
Since I'm changing my oil anyway, I got the Motorcraft filter, a whopping $3.67 (before my discount!). Should be good for 5hp, right?
RUFFSTUFF
GEORGIA
My butt dyno says the Motorcraft filter is good for +3.75hp at 3500rpm. I'll check again tomorrow, this time with the headlights off...
E
Eric
California
I went with Fram XG2 which was $9, as I stated before been using Fram for 15 years without issue. We will see how it goes, I'm using Mobil 1 full synthetic as well. Common sense would say the Fram is as good or better as the OEM (which ELVATO says is a Purolator) since Fram's existance and reputation depnds on the quality of their products. I know the "Motorcraft" OEM battery sucked, so not everything stamped with Motorcraft is great.
