USMCBuckWild
We have a 2001 Expedition since new, ran recommended oil weight till 150,000 miles, adding a can of Engine Restore every 3500 miles. As miles went up , increased oil weight to 10w 40, then when we hit 300,000 miles, I run 20w 50 Castrol in it, still runs great. It now has 360,000 on it, used a Qt between changes. I have always used Castrol, and Fram filters along with Engine Restore. As the engine accumulates miles, the clearances increase, therefore my theory says increase oil weight. We also have a 2012 King Ranch, I am using the same theory with it. It has a little over 100,000 on it, still running 5w 20 Castrol syn blend, but am using Engine Restore. I use these products in every vehicle {6] that I own, boat, has a ford 351W in it, and mowers and such. I have had no bearing failures in 30 years.
While your logic has some merit and truth, i have to disagree with you in regards to the Ford modular v8.
While you are correct in the fact that the bearings/rotating assembly wear down with higher mileage, the oil passages and oiling system (which is designed for a narrow range of oil viscosities) does not change. Too thick of oil and the oil pump can't push it, can't get it through the oil passages, oil filter (which is also metered for certain pressures) to the components that require a SPECIFIC oil pressure to work properly. Timing chain tensioners, cam phasers, cam followers, all require a SPECIFIC pressure.
Not trying to insult your intelligence, but think of it like this:
If you grab 1 straw and 2 glasses, fill one glass with water and one with maple syrup; can you suck the the maple syrup out as quickly and consistently as the water? (Yes I understand the difference between hydraulic suction and hydraulic pressure, this is just a layman example) This is a crude example of the difference in the viscosities of the oils and what the lubrication system is attempting to do.
Yes, in older engines with solid lifters and mechanical timing chain, a thicker oil at high mileage does aid in retaining appropriate pressure in a system designed with oil pressures that are partially metered by the bearing tolerances. But, even then at some point too heavy a viscosity is just too thick. The old used car salesman trick of adding a quart of gear oil to a upper end knocking engine to quiet it down is no longer going to work.
You may not have had a bearing failure in 30 years, but have you had any other failures?
