Wheels seem to be stuck
jered22
Elmira, New York
Ok so I recently tried to rotate my tires. I took off all the lug nuts on the drivers front side tire. When I went to pull it off the tire/rim would not budge. I first thought maybe one of the posts were bent but they are not they are all perfectly straight. I mean this thing would not move a CM. Is there a trick to getting the tires off or are they just "rusted" on? Hard to believe since my truck is not that old. HOW DO I GET THE DAMN THINGS OFF...
Newport News, VA
should come off...take a rubber mallet and knock around it to see it if breaks loose...WD40?
FordandPolaris
Saint Cloud, MN
They are probably alloy wheels. I have this problem with my dad's 04 but not my truck cause mine are steel. Turn around backwards, and give your best impression of a ******* (donkey) kick on that tire. It'll come loose. Just really make sure you have a couple stands under there, im always worried kicking it like that will knock the truck off the stand. Never happened to me, but it doesnt hurt to be safe. Hope that helps
J
jered22
Elmira, New York
Yes they are alloys... Tried removing the center Ford cap and spraying WD-40 and it still won't budge. What am I supposed to do if I blow a tire on the side of the Interstate? Gonna have to pay to have them rotated now they won't move....
sgtowing
Supporting Members
Valrico, Fl
If your brave enough to try this, set the truck down on the tire without the lug nuts on and turn the wheel all the way in each direction. The friction from the ground along with the lug nuts removed should be enough to break it loose. Just make sure you have the jack raised up not supporting any weight under the frame and locked so it wont sink incase it shifts a little.
Notmyidi
oklahoma
Wd 40
Let it sit
Then get a sledge hammer and hit the tire....then rotatate it and hit again only hit on the bottom
Happens on big rigs all the time
sent from my mind via telepathy
Notmyidi
oklahoma
im going to quote myself...
A BFH fixes alot.............
Big hammer to the backside works every :flamingdevil:time!!
Wd 40
Let it sit
And the survey says ......
Rubber mallet? Pshhh dead blow
J
jered22
Elmira, New York
I am going to quote you quoting yourself.... I like the rubber mallet idea a little bit better than the sledge hammer. I will give it a go. If it works I will have to get a second rubber mallet to carry with me on road trips from now on.
RI-Matt
Rhode Island
I was taught years ago to smear a little anti-seize on the back of the rim mounting surface. The wheel gets stuck because the oxidation of two different metals ( steel rotor and alloy rim)
Matt
02expi
Idaho
A rubber mallet is like sending a boy to do a man's job. sometimes it takes several good smacks to break them loose. Of course you want to smack the tire so as not to damage the wheel. :ryu-cvs-hadoken-a:
