When I'm Driving~
VexedEX
I'm a new owner so it could be nothing but sometimes when I'm sitting at a stop light my vehicle shutters a bit. Is that normal? I don't believe it is but I don't know what it could be? :smokin:
Lane24
technical advisor
Alberta , Canada
When you say shutters, do you mean you lose rpm or it just kinda shakes. If you are losing rpm , check the link at the top of my sig. If it is just shaking wierd, maybe it is just really excited to get going again. jk. Give up a little more detail, and someone should be able to figure something out.
VexedEX
VexedEX
Thank you I believe that is exactly what it could be... :dogpile: I will check it and let you know if it is the issue! Thanks again!
jdan
CT
Mine shutters to when idle. It has O2 sensor codes but no cel illuminated.
I'll let you know if it goes aways after I change them out.
VexedEX
VexedEX
Cool thanks... It's not real noticable and doesn't happen all the time. I see it does it more when it's cold out.
VexedEX
VexedEX
Looks like it must have been all the corrosion around battery terminals~ Seems to be running a lot better. Thanks for all your input guys!
