Copper93
I have a 98 Expy and the A4WD light just flashes when the knob is turned. The 4WD and 4WD low seem to work. The speedometer works also. The transmission changes a little hard from 2 to 3 but that maybe another issue. Pulled codes with FORScan and got back an 1845 code, if I remember correctly. It stated a Hall effect sensor shorted to ground. How many speed sensors are there and where are they located. Everything I’ve looked up gives from the front of the transmission, rear of the transmission, transfer case and differential. Which sensor controls what?
