white smoke
R
renee
north carolina
its a 99 ford expedition 5.4 liter eddie bauer edition it was running a little rough that's what made me change them i had someone change them about a year ago
toms89
technical advisor
MD
but wouldn't the smoke smell sweet instead of like gas? The third spark plug i had to use a chaser on do u think it is the oil i used to lub the chaser?
Did you just run a tap through to clean threads or did you install a timesert?
R
renee
north carolina
well i got the chaser and couldn't get it to thread thru then i got a tap and before i went to tap i was making sure there was no shavings from the chaser and found out the mechanic who did the plugs a year ago left a bolt in the hole so all the time and money was pretty much wasted all my plugs needed to be changed tho cylinder 4 was barely getting any fire
sgtowing
Supporting Members
Valrico, Fl
:facepalm: OOOOOPS. I missed that part. Now that I see that, I agree with Tom.
toms89
technical advisor
MD
So you were attempting to install a timesert but one already was installed?!
sgtowing
Supporting Members
Valrico, Fl
Yes I can be a little slow. A BOLT for a plug, thats a new one.
toms89
technical advisor
MD
Well speculating here based on your post....
You were attempting to put a timesert in and doing step 1...reaming the hole out but found a steel timesert was already installed which had stopped the reamer??
Is this correct?
imjuststeven
