Aspen03
That whipple F150 doing that pull in your video is probably a $15k build with everything necessary and the custom tuning work. For about 1/10 of that the ecoboost can basically match numbers. Even if you blow it up at some point you've saved enough for a complete custom motor build...
E85 does silly things with forced induction. I had a GM 3800 on a stock valve train aside from some 1.8 rollers with some nice headers/catback that ran on a 3.2" pulley with 20 degrees of timing and around 12psi in a stock blower which might as well been a heat pump at those rpms at WOT. Most full sized intercooled guys couldn't do that and spent $2k more than I did on parts alone.
