I have a 2000 XLT 4x4 5.4
I would like to firm up the ride as the vehicle dips too much in turns. I peaked underneath the front of the truck and noticed that there is no coil spring or strut, just a shock absorber. Just a regular shock absorber at that, no air lift.
That seems fairly inadequate for the engine bearing part of the suspension and given the vehicles overall girth in general. I see there is a coil spring on the rear but nothing for the front?
Clearly, I'm very surprised by this.
Secondly, is replacing those shock absorbers my only option for trying to firm up the ride and if so what is recommended?
Thanks.
*edit* Ok, so I discovered torsion bar suspension. If that's that main weight bearing spring for the front, what do I need to replace to firm that up?
Thanks.
