Will 35" tires fit on oem 20's?
SOLISIMO
Ft. Lauderdale
Two questions folks:)
1. Will 35 / 12.50 / 20 fit on an oem 20" rim
2. Will this set up fit on a Truxx 3" front 2.5" rear leveling kit with minor trimming
(2007 Expi EL?)
rptr00
Las Vegas
check out the ATX concept Expy EL. They did a one off bodylift with 33's. It looks really good.
SOLISIMO
SOLISIMO
Ft. Lauderdale
Its a 2wd. My wife had a King Ranch F150 4x4 that I swapped out the tires for some nitto terras (305 50 20) and we had rubbing on the inside ball joints.
So Im sure with a mud grappler bc of the sidewall it will rub more. So im thinking of going with 20x10 rockstars with an offset that will push the tire away from the inside. Now Im still torn between 35's vs 33's :( Im even contemplating going with 18s bc I love the small rim big tire look. Opinions?
Expedition
Dallas
I'm not sure, but if you do get the 3/2.5" Leveling kit. Then I think you should be okay. Go with 20s, because if you're thinking about them now. Then when you get the 18s you're probably going to wish you had gone bigger.
SOLISIMO
SOLISIMO
Ft. Lauderdale
Def. going with the lift lol, good point on the 20's btw:)
rptr00
Las Vegas
Coming from someone who has been down this road recently...the only regret your going to have is the price of those 20" tires. 33 or 35 they are expensive. I stepped down to 17 for this reason.
It will be interesting to see an EL with 35's!
