2020-MAX-Limited
Hosed off the Expy today at a carwash and steady Check Engine light was on after driving away. No noticeable engine symptoms, running normally. Considered the fuel door ('15 Expy with cap-less filler) might have broken seal, so I dried it off and made sure it sealed well when getting home. Understand the need for pulling codes to run it down, but was wondering if disconnecting the battery (neg terminal) will reset the light in an effort to repeat the fault before taking to a shop for codes. Am aware of earlier Fords working this way.
