alzikrw777
1 . went to gas station , filled up (yes, absolutely certain put right gas in it and not diesel)
2. started no issue, headed back home,
3. after 500 m, started running rough , shaking, stoped at red light, engine shuts off
4. tried to start it , it cranked but no start, engine light came on
5 moved it on the side, run all modules scan with my blue driver.
6 it came with 2 codes - B1318 - Battery voltage low and B1602 Time since last clear A (Pats) key used has not been read Satisfactory
7. while waiting for towing - bought new car battery..replaced it on the side of the road. --also replaced fob battery - no help- still crank, no start.
8. Car was loaded onto towing truck, delivered at my home, driveway- just for heck of it..tried to start it- and it did start right away no hesitation -
9 . left it runnin gfor few mins - during that time intermitently - started surging rpms then go back to normal just to go bellow normal rpms-
10. started idling normaly- then after a minute or so ....just cut off again - stalled and engine off..
11. attempt to start it - again crank -- no start
12. at least it was in driveway..- checked fuel reset swtich in the back and depressed it few times- no help
13 - disconected both terminals from battery- left it over night - approx 24 h- plugged battery back in- started without hesitation-run on idle normaly for 15 minst - no issued idling- didn't drive it for a risk of cut off again.
i thought it was fuel pump but it doesnt make sense that i can power it up after battery reset..assuming if it's bad fuel pump it won't send fuel regardless.
didn't replace fuel pump relay yet
anyone have any suggestions or similar experience i would appreciate it.
thanks
Aleks
thanks
Aleks
