Woofer noise after i drive over rumblers on the street
Qatarguy
Qatar
Hello
I recently purchased a 2011 Expedition King Ranch with 31,000 miles on the meter. I'm experiencing a strange problem: 9 out of 10 times, when i run over a speed hump or a set of rumblers on the street, the woofer starts to give out a strange, very deep sounding rhythmic thumps, approximately 5 thumps a second.
Nothing i do will stop it thereafter until i power down the entertainment system.
Any idea whats causing this to happen, and any cheap fix? All inputs are welcomed with thanks
Newport News, VA
Gotta be a short somewhere or wires touching somewhere...u'll have to follow all wires to head unit and to rear sub/ amp
Mr. 10K
Qatarguy
Qatarguy
Qatar
Thanks for your suggestions, 10k-watts and ablivion. As it turns out, the problem has not occurred after i found a ****** CD in the CD Changer...While fiddling around with the Head Unit, i found an old...really old.. audio CD, in the CD changer. Found it by chance when i pressed eject several times...seems the previous owner left it there. As the Head Unit is also a shoddy job done by the previous owner in replacement of the OEM head unit, there was no indication that there is a CD inside. Each time i went over a bump, the CD seems to have created the sound in the audio.
Qatarguy
Qatarguy
Qatar
Apparently not the CD problem after all. Going to open up the panel to check out the sub/amp...
