Pwr pedals and seat
drspddmn
Woke up the other morning, truck wouldn't crank. Jumped it off, took it to the parts store and put a new battery in it. Now the pedals and the seat don't work. According to the owners manual they both operate off the same circuit so I checked the fuse. It was fine, I replaced it anyways and it had no effect. Any suggestions?
D
drspddmn
Yes, we do have the memory feature. I downloaded and printed the wiring schematic(s) from BBB Industries and checked all the fuses on those schematics. There was only one however that has all three circuits running through the same fuse and that fuse is good. Tested voltage in and out. That particular fuse/circuit runs to the memory module.
D
drspddmn
p.s. The power mirrors aren't working either. Like I said, all these are on the memory system so it could be a faulty memory module, but do those commonly go bad???
Bedrck47
Elizebethtown, PA
did you check the ground connections for these circuits if not they are located behind both kick panels in the front G300 G301 and G200
Your schematic(s) should show all the grounds
D
drspddmn
I'm not sure how to resize the files for it to attach, they are too large. But I see the ground areas in the diagrams. I have not checked them and I didn't notice if that stuff worked before the jump stamp but they did not work after, thats for sure.
