Muddy Bean
Um I drove it? In a ton of snow. Michigan got nailed this weekend.
Habbibie
Is it Christmas yet?
Chicago
I didn’t do as much as u guys been doing lol, I just for the first time in a year or so finally engaged 4X4 low to get out of a sticky situation.
Had to go down an alley that had 18 or so inches of snow on it and no pervious tire marks so I knew I was gonna get stuck if I roll into it in 2WD. It struggled but did eventually pull me through it till the end but again it struggled lol my undercarriage was pretty much a plow at that point.
Flexpedition
midwest
Replaced a leaking heater hose. Motorcraft KH-509. Cracked plastic connector spraying antifreeze on the passenger header - foul smell and steam. Replacement is longer than original, few hours after the install learned it also replaces a short extension off the firewall. Probably will remove that extension for a better fit.
Adieu
SoCal
Careful.
That one tends to put coolant in plug wells, killing your coils and creating misfires
gave the interior a once over clean and ran through car wash, this winters been harsh.
GaryH2
SE PA
Replaced the driver's side window regulator and motor. It's never worked better!
Also pulled the codes to see what was going on with the PCM.
Sent from my XT1585 using Tapatalk
