What mpg losses have you guys gotten with this setup? For example if I cruise at 65-70 mph without stepping on it, is the mpg worse or the same? Not stepping on it I should technically be using the same amount of power/load.
Good Luck. A "Roots" type blower sits on the top takes oil from the motor and cools the supercharger. When the motor goes you risk the chance on putting metal into the supercharger. Procharger is an external blower of course and is self-contained good thing. Every time you change oil you also change oil in the supercharger, it uses its own oil. BUT with any motor, build the engine for a supercharger. If you just use a normal hyperutechtic (I know the spelling is wrong!!) pistons no matter how new the engine you will blow a piston within 12 to 20,000 miles, I guarantee. Will need to build a bulletproof bottom end first. Forged pistons, rods, crank,etc. Some places you can get kits are D.S.S. motorsports and Sean Hyland Motorsports.
no way eh so I guess my dream of a super charger just flew out the window lol no way do i have 2500 or more for a supercharger and then be replacing my motor within a yeardarn so i guess it'll be intake exhaust and a tuner that's about it ? let me know thank you
