04 expedition wont stay on.
Sarahjo
Arlington, TN
04 expedition with 215000 miles. The past month or so while driving at any speed, it would randomly jerk. Ran my codereader , and it said pcv valve. I replaced that, and it didn't jerk for at least 2 weeks. Then pulled p2198. I replaced bank 2 sensor 1 o2 sensor. It started right up and idled super good for a couple minutes and died and now won't start. I know sometimes the maf sensor can cause it to drive bad and throw codes for 02 sensors. I replaced that. I had the fuel pump and filter replaced 2 months ago. Any ideas at all from you wonderful folks? I can't afford to put it in the shop right now so I'm trying to figure this out myself... and failing.
Sarahjo
Sarahjo
Arlington, TN
Another update y'all, put a new fuel pump in, and still won't crank. Back to the drawing board.
Yupster Dog
Super Moderator
Super Moderator
Now they say they think it's the fuse box.
Well known problem. Here is a thread on the subject. (it's a sticky in the 2nd gen section)
Sarahjo
Sarahjo
Arlington, TN
Fuse box has been replaced, still won't crank. This has gotta be fuel related. The fuel pump is turning on when key turned to on position.
Hamfisted
Ft Lauderdale
When you say "crank" do mean it won't turn over at all? or it just won't "start" and run? Any DTC codes stored in the computer?
Sarahjo
Sarahjo
Arlington, TN
Sorry. Will crank, won't actually start and run. No codes at all. Having to pull in 2 ford "specialists" from what I'm told. Hell, by the time this is said and done, I'm going to be a specialist.
Sarahjo
Sarahjo
Arlington, TN
Well i got my expedition back today. She runs so good, BUT now the adv track won't turn back on, none of the doors lock unless you manually push the locks down, and the back door won't open, i guess bc maybe it's locked since the lock/unlock buttons won't work? I took it right back to the shop.
edyk1986
