Bedrck47
The 03 only has ONE fuse box
One common problem that could cause you blower motor not to run would be if you disconnected the ground wire for the blower relay and motor when you made the repairs.
You need to find the relay and check to see if you have voltage going into the relay both for the relay coil and for the contacts.
The relay receives its power from the EATC and that will cause the contacts to close The contacts receive power from fuse 107
