2004 Eddie Bauer 5.4 liter A/C blows hot only on hot days
Discussion in 'Heating & Cooling' started by jleroy68, Jul 11, 2017.
  1. jleroy68
    jleroy68 Member
    Jun 8, 2013
    Arizona
    Compressor not turning if I shut engine off after driving enough to get engine hot, and restart on any day over about 90°. If I leave it running it’ll stay cold but the second I turn it off and restart hot air only. Fine on days below 80-85°?
  2. docraymund
    docraymund Full Access Members
    1,000
    77
    Feb 14, 2011
    philippines
    You may have a restriction in the system causing the compressor to automatically shut off during hot days. Have a reputable ac shop check it.
    jleroy68 likes this.
  3. stamp11127
    stamp11127 Super Moderator Staff Member
    60
    4,824
    585
    Mar 10, 2012
    Temple, Georgia
    Jleroy68, how are you with electrical troubleshooting?
  4. jleroy68
    jleroy68 Member
    Jun 8, 2013
    Arizona
    Not to good, but my son in law is.
  5. stamp11127
    60
    4,824
    585
    Mar 10, 2012
    Temple, Georgia
    When the system isn't working (better with a "cold" engine) you check for power at the fuse then the ac compressor connection. Engine running, ac set to max. If there isn't power at the compressor you follow the wires back to the source checking for voltage at each connector or splice. At some point you will have power on one side of a wire or connection and none on the other.
    If you have the electronic control ac, run the diagnostic routine first. A failing EATC module can kill the system at any time or temp.
  6. jleroy68
    jleroy68 Member
    Jun 8, 2013
    Arizona
    Ok, appreciate the advice. Thanks.
  7. stamp11127
    60
    4,824
    585
    Mar 10, 2012
    Temple, Georgia
    See Fuse testing 101 in the electrical section on testing them in place.
  8. jleroy68
    jleroy68 Member
    Jun 8, 2013
    Arizona
    I’ve done that. The thing I can’t get into my brain is there’s no problem as long as the temperature is appx 85° or less it works just fine. But when I get into the 90’s and shut it off it’ll just blow hot, usually til the next morning. It’s got to be something maybe under the hood that is affected by heat. I’m thinking what docraymund said makes sense. Unless there’s a relay under there that gets stuck when hot?
  9. stamp11127
    60
    4,824
    585
    Mar 10, 2012
    Temple, Georgia
    Ok, let us know what you determine.
Share This Page
