My rockers are rusted out. I found a PAIR on Amazon for 90 bucks. Yes they are 'slip on' rockers which are a cosmetic fix. That works for mine since mine is cosmetic. I am going to cut out the metal that has rusted completely. I am going to clean as much surface rust with brushes, wire wheels etc. Once that step is complete I am going to apply rust inhibitor/restorer paint to the underside/inside of the inner rocker. I am also going to coat the underside and outside of the slip on rocker. I am going to tack weld the slip on rocker and 'hide' the seam under the trim.
I'll keep you posted if you'd like.
