Earl Woodside
I have upgraded my Expedition Radio to a Double Din Kenwood. There is no kits available but thru research have found that the 2014 F150 Radio Dash mount kit works with very little modifications and unbolting the factory metal brackets on the factory radio. you will have to drill out the dimples in the factor brackets and next size up on the bolt holes to allow for the screws to attach to aftermarket radio. I used a Kenwood and found the two holes match up perfectly. for the wiring harness you will need the CAN harness (more expensive harness mine was 79.00)(years 07 - 17). Hope this helps you out in order to put in a aftermarket radio in your 2016-2017 ford expedition with a base radio.
