Almost Stranded by my 2016 Platinum
aldwarii
Riyadh
Hi!
Any updates about this issue ? I have the exact same issue on my 2016 Expedition
JasonH
Houston, TX
Previous comments suggested it was the throttle body. Try pulling codes with an Elm327 Bluetooth adapter and Torque App. Mine had to be replaced around 80k. If it's the throttle body that's an easy fix.
aldwarii
Riyadh
These are the codes I got
P0087
P008A
P00C6
P0627
All are from the continues memory DTC. Check engine sign appeared at the day of event and disappeared at the same day
JasonH
Houston, TX
P0087
P008A
P00C6
P0627
Try this thread:
aldwarii
Riyadh
Thanks Jason!
My car is still starting, wondering if the same principle applies to my car?
JasonH
Houston, TX
With the same codes ?
That is a relief. throttle body is way easier to replace, and cheaper ;)
Thanks in advance Utah
Can confirm. Mine went out while my wife was driving to work. I grabbed my tools and replaced it in the parking lot. I would definitely start there. Having said that, the code I got for the throttle body failure was different from the ones you posted. But for the relatively low price and time required to replace the part, it's worth a shot to see if it fixes your issue. Otherwise, it might be something in fuel system as related above.
sharprd65
