Battery light was on when I bought the exp. Since then I've replaced the battery, alternator harness, and cleaned all connections.
Light is off after starting and only comes on when I shift into gear or press the brake.
Today I tested with a multimeter and I have around 12.6v charge with the car off, 14.64v running with all accesories and sub/amp powered.
No voltage drop between posts/terminals/wiring/alt/bracket/body ground.
Never had any issues with the car not starting. Battery was replaced for extra CCA (old battery was a small Valucraft with only 405CCA).
Should I check anything else or just have the light shut off?
Thanks
*Forgot to say the alternator is a World Class remanufactured. I think the company is out of business or name changed but the best I could find is that it's a 135A made for the Crown Vic.
Thanks
