Battery Light
humper
florida
Hello all. Have been a member for quite awhile but never posted. However, I have an '08 Expedition and on the gauge where the info shows up a battery light constantly stays on. I'm having charging issues so I've replaced the battery and the alternator, but still the lights and charging issues. Any ideas? Appreciate any info I can get.
Hamfisted
Ft Lauderdale
Do you have a multimeter ? How much voltage are you getting at the battery with the motor at idle ? Where did you get the replacement alternator from ? If it's not a NAPA or Motorcraft alternator you can probably throw it in a canal.
Motorcity muscle
Motorcity
Need to check componets not replace them. Easy to load check a battery and check charging voltage with the engine running. Older trucks are prone to corrosion/rust on cables/connections.
Vdubnick
idaho
had similar issue on another car, ended up being a broken signal wire at the alternator, broke within the wire jacket, so it was intermitant at first, hard to pinpoint without a meter and wiggling stuff around.
H
humper
florida
Motorcity, I only replaced the battery and alternator after they were tested and said to be not working. Have since,February 1st replaced battery again but the light is still on.
twodollars
I'd start with checking batt voltage with engine off and running with some electrical load.
