Brake pads
TobyU
Ohio
Just curious if you have ever used higher quality pads and rotors. On my jeep I have now used several of the "store brands" and all felt about the same and I felt they worked about the same. On a whim, I tried centric rotors and EBC yellow pads and it made a huge difference. It was way more expensive than everything I had used in the past on the jeep but it was significantly better. WAY more dust and noisier than anything I had used but stopping is better and I haven't experienced fade like I had previously in fact they seem to get more grabby when they get hotter. Previous to this I was looking at getting a big brake kit for the jeep to help stop the 35's, now I don't feel like it is needed.
I personally don't feel the brakes are that bad on the expedition, so I don't know that I will use anything special on mine.
Well, I've never used any slotted or cross drilled or anytime special rotors but I believe I have used some at least brand name or higher performance pads over the years on some vehicles with large tires. I had a 79 Ford with 44 in Ground Hawgs on it a Ramcharger with 35s and a Durango with 38s. I don't actually remember having any stopping problems with any of them. But I might have put some Bendix on them instead of just the store brands.
You can certainly alter stopping characteristics by changing the composition of the pad. And as you said a very crabby pad is probably going to create more dust probably wear out the rotors faster where is a harder pad or ceramic might create less dust and even have less brake fade but not have as much grippy stopping power. I've just never really owned a vehicle that didn't have more than adequate stopping ability except for maybe one. I bought a 36 ft long Excursion stretch limousine back in 2007. It had 86000 miles on it then I felt the brakes could have been better. Maybe just a nature have a huge vehicle that's been altered and not really over-engineered to have more than enough Breaking ability but that's the way they are. As soon as I got it I went through all four brakes and replaced rotors calipers and pads. I can't say that it stopped a lot better but at least felt like I had more stopping ability. I got a little over four years out of those until the rotors were starting to rust a little bit and separate at the ends. These were still just wearever from Advance Auto Parts so it's not like I was buying the most expensive that for years is great for those or for anything on that vehicle. Then the next set came from O'Reilly Auto Parts and they lasted until I got rid of the vehicle which was over six years. So I would say the quality was definitely better with the O'Reilly brakebest as opposed.sed to wherever at least at that time.
edizzle
Cashiers
What tool is that? Rotor not motor?
My tool for removing the rear rotor is a sledgehammer. Its ugly.
Foxwell OBD2 scanner. it allows you to retract the electronic parking brake (EPB) motor. then when complete, it activates it.
ANGEL TORES
HALEDON, NJ
I just recently did my brakes about 2 weeks ago and I shopped on rockauto.com. Price was competitive and I went with the PowerStop Heavy Towing Kit. Replaced rotors, pads and calipers. Calipers came in a nice red powder coat.. I tow a 30ft camper and I am very happy with performance. I agree with Atrie with the whole Ford missed their mark by not putting out better performance in the brakes. Is what it is I guess. Hope this helps, good luck.
MostlyHarmless
Maryland
Hmmm, maybe some cars are easier to feel differences or some people just feel the brakes more, but I have never noticed any difference in action or ability. I have once or twice felt hot brake fade that would have been less with other pads and/or rotors.
Brakes on my cars feel the same when they are down to under 20% pad left as they go with new thick pads. Every vehicle I've ever driven the brakes even feel the same the pants were down and they're grinding into the rotors. It stops exactly the same you just hear the noise and feel a tiny bit of vibration. New pads will often have a little bit of noise and a slight bit of roughness you can feel new pads will often have a little bit of noise and a slight bit of roughness you can feel when that fresh. But I have never noticed anything that is worth comparing or that would change my buying preferences. Now if I were dealing with a high performance car at high speeds or very hard driving, I very well might consider and upgraded quality pad and are rotor I see no need for daily driver normal vehicles. These cars all have more than adequate braking systems. Now people that tow any good amount of weight may certainly enjoy some upgraded stopping ability but or just using these vehicles by themselves I've never had the need.
Toby, you have a fair point. Most road cars are calibrated similarly.
My guilty confession is that I spent about 25 years racing karts and cars at a serious amateur level in Europe (I am originally from the UK.) So I do tend to be hard on brakes and “forget” I am driving an Expedition :)
So I’m probably not a typical user im that I prefer a pedal with more initial bite and pedal progression than Ford wants to give me from the factory.
P.s it’s a minor gripe and largely influenced by my driving style. Apart from this I LOVE my Max Limited 302
jowel
carson
there is a company name max advance brake that's is where i bought my brake pads and if you want the upgrade for brake rotors they also have and the brake pads that they selling is all ceramic pads check them out
Bilsto
Nashville TN
I don't know what's on mine, they were freshly done right before I got it. I suspect they're the Auto Zone cheapies. They've been okay. For what it's worth, I shop www.RockAuto.com for that. Excellent array of choices, and their prices are unbeatable, even with shipping.
rumline
Colorado
I just had my Expy in for an oil change and the complimentary inspection noted that my front brake pads are down to 7/32". I only have 14k on my Expy and I have young children so I generally drive like a grandpa. WTF? Are others experiencing similar wear on their Motorcraft pads?
edizzle
Cashiers
absolutely not! we got 35k out of ours and that was HARD DRIVING. I mean aggressive mountain driving constantly on the brakes.
Plati
Where did you get the "complimentary inspection"?
Do you trust them?
Certain chains are going to use that as a sales tool to sell you something ya don't need.
Can you check it yourself or have it verified?
rumline
Colorado
It was at the local Ford dealership. I don't distrust them, yet.
I'm not opposed to checking it myself but I'll have to read up on it. What tool do you use to check the thickness?
jochris72
