yeah the reduced pressure probably does more good. less wear on the injectors and that lolford plastic i fear is lurking somewhere down the line
Everyone here is correct. Your assumptions are not how it plays out in fuel injected systems.
There is no such thing as increased wear and tear on fuel injectors. There is debris clogging them up and too little pressure to fire(spray).
A fuel line leaking or blowing out is same in all but one place (I'll get to that in a sec) whether you have a no fuel filter, a new one, or a restricted one.
If you have a restricted one....the pressure is still the exact same past the filter in about 3 seconds. It's builds up to the same whatever pressure the pump and regulator allows it to.
If the filter is restricted, it lowers VOLUME of fuel which affects engines running and driving but does not change the peak pressure it hits once it is sitting there with key on engine off or idling using far less fuel than the pump provides.
NOW IF the filter is clogged up, the tubing from the pump in tank to the filter DOES spike in pressure until the flow works it way through the filter media.
This is not only bad on the pump as other have stated, but could be bad on that part of line..which goes against the theory you stated, BUT is not going to happen because that is not where the lines rust and get weak. They typically rust after filter along frame rail.
I have done lots or filters in my life and only seen two that were really clogged.
One I could barely blow with mouth through it and other not a chance! The more open one still ran fine. The severely clogged one ran but at hard or full throttle starved for fuel and surged badly.
A 150K fuel filter will only give a little resistance to blowing through it and the human mouth can only blow like 1.5-2 psi (golf balls through garden hoses are different).
A lot of the slight restriction you will feel blowing though an old one is just the wtting of the media.
Wet the new one and it much closer.
So in reality, it's not going to make much difference.
You will get a little better flow but negligible with new filter in 95%+ cases and you will get even less increase with NO filter vs new one.
So change the filter or forget about it. Removing won't help you.
If pump is weak, change filter and also get at less than 1/4 tank and put a whole quart or MMO Marvel's Mystery Oil in the tank.
That will lube pump and often helps.
