When my starter was going out, it just made a single click or light chunk/clunk sound. Tapping it with a hammer as Stamp suggested got it going. Luckily, I picked up a reman new one from Ford. It got so bad within just 2 days from first no start, that I thought I was going to have to tow home. I got one last crank over by tapping at least 6 different times. Theirs a starter solenoid on your passenger side firewall. You also have a solenoid piggybacked on top of your starter like GM's do. It is very possible that one of the 2 is failing. Theirs tests, but the fact that your problems intermittent, you might want to test and or replace the firewall one first. Check the connection on those cables, they come loose sometimes. Also the push on wire from the key switch at the solenoid, be sure it's clean, and a snug fit. Normally we here believe in testing first, but your problem may, or may not show on a continuity test.
