Intermittent Passenger Headlight Operation
EdWeg
Birmingham, AL
2007 XLT passenger headlight cuts on/off intermittently. Replaced bulb (thought it had burned out) and continues to do. Sometimes clicking on the fogs will activate, or flipping between all switch settings will; but, always seems to go back to intermittent on/off operation. Connections and wires seem to be intact without frays, etc. Any ideas on what could be causing it?
ExpeditionAndy
Fort Wayne, Indiana
I had a similar problem on my 05. I narrowed it down to the switch. It would do the same thing every once in a while. If I turned the switch to any position but auto (I always kept it on auto) and back to auto it would come on. If it bothers you try to get a switch from a junk yard it will be cheap, otherwise, $24.79 for the Motorcraft switch on Rock Auto
http://www.rockauto.com/en/moreinfo.php?pk=1004214&cc=1433530&jsn=456
http://www.rockauto.com/en/catalog/...lectrical-switch+&+relay,headlamp+switch,4472
EdWeg
EdWeg
Birmingham, AL
Thanks. Lately, it won't come on no matter which way I turn or pull the switch...I hope it ends up being that; better than having to trace a wiring issue. Like your ride!
ExpeditionAndy
Fort Wayne, Indiana
Thanks Ed,
The other thing you can try is to remove the connector and re-seat it to see that helps, but the switch is cheap.
Adieu
SoCal
HID?
Try adding a relay harness AND capacitors
EdWeg
EdWeg
Birmingham, AL
Yes, I replaced originals with a pair of 100W HID 5000k brightness. You don't think it could be the switch or connector?
EdWeg
EdWeg
Birmingham, AL
I've reseated the switch to no avail; so, replaced the switch with a new one, and there's been no change in the operation of the passenger low beam light - it still won't come on - at all. No amount of fogs on/off, or switch setting activates the passenger low beam now. Any ideas on what could have suddenly caused this issue/problem; and, how to fix it? Or, do I need a mechanic with tools?
ExpeditionAndy
Fort Wayne, Indiana
If I'm not mistaken, a 100 W HID draws more current than a standard 55W halogen. It is possible that you have a burnt connection where the factory wiring plugs into the ballast. This going to be one of those tedious troubleshooting problems because you are going to have to trace the wires back until you find the problem.
I'd start by swapping components left to right to see if they work on one side and not the other. This will eliminate the components. First swap the bulbs from the side that works to the side that doesn't. Then put the bulbs back where they originally were, then swap the igniters (if used) from the side that works to the side that doesn't and see if that makes a difference, then switch them back. Finally swap the ballasts from the side that works to the side that doesn't work and see what happens.
Once you have cleared the components then start with your multi meter checking for voltage. and looking over the connectors and the wiring for burned spots.
Just my 2 cents worth. I hope it helps.
johnjohn205
