Lift and tires. Need help
Bronco72
Southern Indiana
Great info everyone, Thanks! I am looking to pull the trigger on my setup this week but I am struggling to go with 35's knowing that there is some rubbing. This is my wife's vehicle so I know if there is any rubbing I am going to hear about it.... I'm looking at going with the 3/2 Easy Lift, Method NV 18" wheels, and 33" Toyo Open Country ATII's. Anybody have any pictures with the 33's?
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Split the difference... Go LT285/75R18 or LT295/70R18 in the ATII
Bronco72
Southern Indiana
Very good point... I don’t know what it is but I always struggle not going with the standard inch sizes on my trucks. I’m running 33x12.50 DC Trail Country’s on my early bronco and F100. Old habits die hard. I’ll update with some pictures once it’s all said and done. Thanks for the input Loki!
Vancouver Bob
Vancouver, WA
Just wanted to add that dealing with the rub is an easy fix... at least for the gen 2's... can't speak for the rest. Just a little trim of the lower wheel well material and a little from the front of the running board.
limitedex
Ok
33/12.50/20
25631579363_ab4c672b0e_k.jpgIMG_1327 by limitedex, on Flickr
26141803752_00343e8662_k.jpgIMG_1325 by limitedex, on Flickr
25629521594_a371dd98ed_k.jpgIMG_0373 by limitedex, on Flickr
LokiWolf
Super Moderator
Super Moderator
Richmond VA
They are both in the 34 range, but in the 11’s for width. So taller and still wider than stock. The 12.5 width is really what causes the rubbing. Split the difference and you are perfect.
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Just wanted to add that dealing with the rub is an easy fix... at least for the gen 2's... can't speak for the rest. Just a little trim of the lower whell well material and a little from the front of the running board.
Electric Running boards that I am running prevent much of not all of the trimming.
