1955moose
- Joined
- Nov 23, 2014
- Posts
- 5,981
- Reaction score
- 1,338
You probably have a lot of play in the timing chains, not a bad idea to change. A lot of work. Be sure you check cam timing before you pull off chains, make sure you didn't slip a tooth on one of the cams. As far as the intake gaskets, you can spray old ones for leaks. If your going to swap out intake gaskets, you'll want to replace plastic intake, they give way. Good luck , you really like digging into this one. Plastic cam tensioners will have to be replaced as well with over 200 k.
