Stevie_Fresh
I'm gonna drive this thing off a cliff soon. There's no fluid leaking anywhere. Bled the brakes all around. No changes. Bought a master cylinder, bench bled, installed, and bled/flushed all the lines again. Seems as though the pedal is stiffer, but only a little bit. Brakes work sometime just fine. (Haven't taken it out of my driveway, just quick gas and brake in the driveway) seems almost like the anti lock brakes are kicking in. Only sometimes, I can feel something in the pedal, and it basically goes to the floor. Let the pedal up, press again it's fine. I know the sensor in the axle is bad, have a new one just haven't put it in yet. But the main abs fuse in the panel under the hood was pulled, so the system should have been DE activated. Can that sensor cause issues with brakes even with the abs disabled??? I'm going nuts, someone please help!!!!!! Lol
