Miekk
The power board deployed about half way down and when it got stepped on I heard a sharp snap. It went up and down a few times then wouldn't stay up. It's on the passenger side. I drove it up on the ramps and started looking. It turns out that the main drive arm casting that has the wedge block in it broke and well, nothing but bad thoughts of "you have to buy the entire thing" came to mind...
I attached some pictues, where can I find this part and how does that lower pin come out??
While I was already there, I removed the gearbox and took it completely apart. Not the motor, just the gearbox. It was almost completely dry. I flushed out the rest of the crap, reloaded it with grease and assemblet it back together. It's nice and quiet again now.
Little trick to keep the board up now that it's broken. manually push it up and use a vise-grip C-clamp on the bracketry. Don't foget to unplug the motor...
Thanks for your help!
