Miekk
For those that want to take the gearbox out, open it, clean, and repack with grease. Remember the wedge block is what ties the power board arm to the motor shaft. In order to get the motor out, after removing it's mounting bolts, the wedge block needs to be removed by backing the screw out about 1/8 - 1/4" and taping it in with a hammer, this dislodges the wedge block so it can be removed. After that the board should move freely up and down and the motor should rotate easily. The gearbox should work its way forward this way.
I had someone open the door and when the board was half way down, I unplugged it so everything was in the center of the stroke. It was much easier to work with that way. Same when putting it back together, have someone open or close the door and run the motor till the gearbox flat orientates where it's easiest to get the wedge block back in.
Remember not to hit on the end of the motor shaft or it will mushroom and when it goes through the arm, it will expand it and break it open as is what happened to me. Also, don't over tighten the wedge block or the same thing can happen. I think that's why the screw was designed so small as to prevent this.
Here's a pic for reference. Yours shouldn't look like this one, if it does, its been a bad day!
Anyway, good luck.
Anyway, good luck.
