Recommended torque for caliper and slides
M_M_
Illinois
I'm about to change front pads and rotors on my 2013 and I've been trying to find out the required torque for the caliper and slides. The settings I've been able to find online are not vehicle specific and are all over the place, so hopefully you guys can help.
Also is there specific grease I should use on the slides? Finally, should I replace anything else while I'm at it?
Thanks a lot!
Temple, Georgia
Caliper grease.
You are one of a few that will torque the bolts. I usually snug them up. You can use the standard torque spec chart for bolt sizes and pick the middle of the range.
Bedrck47
Elizebethtown, PA
These are for the 2010 model year
Torque Specifications
Description Nm lb-ft lb-in
Brake caliper anchor plate bolts 250 184 —
Brake caliper flow bolt 40 30 —
Brake caliper guide pin bolts 37 27 —
Brake disc shield bolts 18 — 159
Brake flexible hose bracket-to-frame bolt 17 — 150
Brake flexible hose bracket-to-spindle bolt 30 22 —
Brake tube fitting 17 — 150
sharprd65
