mpsjr
I have a problem with my '99 Eddie Bauer (5.4l). After slowing down, it will usually stall if I try to accelerate before coming to a complete stop. For example, if I am approaching a red light, and slow down to the point where I am about to stop, and the light changes, when I go to speed up, the truck will sometimes stall. It idles fine, and will accelerate without any problems from a dead stop. In fact, if, in the situation I described above, I come to a complete stop, there are no problems with accelerating/stalling whatsoever. There are other times it stalls as well. If I am slowing down because of someone turning in front of me (or if I am slowing down to make a turn), and then go to take off again, it will do the same thing. It will happen very predictably, anytime I slow down to under 10 mph and then accelerate without completely stopping. Very rarely, the engine will die and I have to shift into neutral and crank it back up to get out of the way of traffic. It always cranks right away.
This problem started around October of last year (2011) after I had to replace the fuel pump and filter. I have since installed another new fuel pump thinking that it may have been the problem, but that did not help (the fuel gauge on the new pump was bad anyway so it was a good enough excuse to replace it). It also does this no matter how much/little gas I have in my tank.
At this point, I do not know what the problem is. I would suspect the IAC, but as I said, it idles fine. It also has no problem accelerating from a complete stop. I also thought about the TPS, but did not want to replace it without asking for help here first. With the combination of braking followed by immediate acceleration, I would also suspect a vacuum problem, but have NO IDEA of where to even begin looking for something like that. I figured someone on the board might have experienced similar issues, and it never hurts to ask. Any help you guys can give would be greatly appreciated. TIA.
Matt
Matt
