Start on second crank
Bedrck47
Elizebethtown, PA
like bedrck said, replace the relay.
Get it correct
I did not say "replace the relay"
What I said was
After you check fuel pressure post the results Keep in mind it could also be a problem with the fuel pump relay on the circuit board in the fuse box
H
Harry
Dallas tx
The next time your drive like this and prepare to start the engine, turn the key to "run" but do not crank the engine. Turn it off and repeat. Then try to start the engine.
If it starts, it indicates the fuel pressure regulator is leaking pressure back into the fuel tank. By turning the key to "run" twice, you are enabling the fuel pump to pressurize the fuel rail before you try to start the engine.
After the engine starts - does it run smoothly or rough? If it starts and runs rough, it could indicate one or more fuel injectors are sticking open - allowing raw fuel into the engine when you shut off the engine. If it runs smooth, the problem is probably the fuel pressure regulator which is part of the fuel pump module.
I've tried that. It runs smooth.
H
Harry
Dallas tx
I've tried that. It runs smooth. If it is the regulator should I just buy the pump?
H
Harry
Dallas tx
So might as well by the fuel pump I guess. But I'm still gonna do the pressure test.
